A couple of points i think should be brought to your attention, if you install a new circuit anywhere it is notifiable work, make sure you notify relevant council or be part of a scheme, if you are part of a scheme you should already know a minor works certificate is not appropriate, next point is why are you installing a shower in 6mm, really now you should only install in 10mm.
One final thing, have you checked the main bonding cables are big enough? You wouldn't want to have to do that for free when you get there later.
The price is irrelevant, different people in different areas will pay and charge different amounts, you will get a better feel for this as you go, if you get the job and you can make it pay your price is spot on.
Sorry its a bit preachy but i do feel on here sometimes the questions asked are a bit irrelevant.
