newfutile
Supporter
In the EIC the above label has a tickbox.
does this refer to selv/pelv , out of reach and so on ,or is the fact its in an enclosure applicable ?
Solution
I've assumed it means "have you used any of the protective measures listed in chapter 41 other than ADS in any part of the installation"
410.3.3 leads me to believe this includes within final circuits as it says "in any part of the installation".
I have to admit I haven't thought about this much, the most common situation probably being if SELV/PELV is used.
Solution
In a dwelling the most common other (than ADS) protective measures are electrical separation for one item of current using equipment (shaver socket), and SELV/PELV.
A tick in the box on the EIC indicates the presence and effectiveness of these other methods. If no other protective measures are used, then it's N/A.
I'm not sure what the OP is referring to when he mentions an enclosure?
newfutile
Supporter
hemel hempstead
United Kingdom
Electrical Engineer (Qualified)
Protective measures other than ADS?
Solved
View solution
newfutile,
loz2754,
