Discuss Quick Volt drop Q re Table 4ab P 383 Regs Book plz in the UK Electrical Forum area at ElectriciansForums.net
John-
Hi
I am being thick i am sure. I am doing some pre work on an EV charging course i am doing in November. I got to a part mentioning volt drop and ref in the regs book. Not looked at this for a while, so i thought i better check it out. Table states figures for Public Supply and figures Private supply. What do they mean by Private and public please and why should there be a difference? Also i see that in the note section the longer the run, the more lenient it gets by adding on an additional .005% up to a max of .5% - i think. Why is that?
IBTWi get the part about being suitable for the equipment supplied, Motors, sanative kit and that this is not a reg just informative i think.
Johnm
The clue is to be found at the bottom of page 381
My understanding is that a 'private' supply is effectively anything downstream of an isolation transformer or generating plant (ie, say you had an AC motor used to rotate a dynamo for DC output). Happy to be educated though.
Reply to Quick Volt drop Q re Table 4ab P 383 Regs Book plz in the UK Electrical Forum area at ElectriciansForums.net
Hi, go easy on me please, I've just returned to the trade, well I am about to, I received my Gold Card last Thursday. I've been gen'ing up for a...
I am trying to understand 3 phase volt drop. I understand single phase VD. Lets say we have a 70 meter run of 35mm, 5 core cable from the supply...
Just taken deilvery of an Electric Car (Mini Electric) and so doing some research into installing a charge point. Supply is a standard Single...
4K
Hi First time with this kind of a job for me. I have a scenario where i am planning to install about 50m 25mm TPN from a TNCS supply to supply a...
6K
Hi all, I am currently doing my 2391-52 and have been given a mock paper, one of the questions is around vold drop as per below, can someone...
5K
