M
Martin0037
Thanks Jason. Yeah I thought could be the RCD so I nipped it back and swapped it and it does the same. I also thought it was my tester at first so I did a test at my house (same system) and it works fine thank god.
I suppose even if I'd have changed the board I would still have ended up with same problem. Customer just told me they'd had a boiler fitted not long ago and the muppets who did that didn't even bother putting on earth sleeving inside CU so ill check what theyv done.
Cheers
Cheers
