L
lee sparks
Hi Chaps,
Started to venture into doing my own jobs more often now and had a small bathroom job come in.
Its just a centre light position and mirror light with pull-cord inside bathroom and a spur for tail-rail.
The CSU is a old MK sentry(1991) so no RCD protection.
The above works are going to be a addidtion to wiring already in place.
My question is, can i install a RCD spur for the tail rail and a RCD spur for the lighting? does this cover me regulation wise.
So it gives RCD protection to the bathroom.
Lee.
If a dedicated circuit, then providing seperate RCD protection to the special location (bathroom) is required for the circuits you install. Along with this however comes the other requirement of gas/water bonding. There is a way around this with supplementary bonding but then you will then probably fall foul of RCD for less than 50mm in wall etc ...... In a nutshell I think you will find an RCD is required which even if it wasnt would be a sensible precaution for a new circuit.
There is also the zoning consideration for where the tail-rail (towel?) is and and FCU you may protect it with. Plus special location work (bathroom) is also notifiable under Part 'P'
