Discuss RCD trip out in the UK Electrical Forum area at ElectriciansForums.net
S
Simon Hall
I've been called to a job for a friend as his swimming pool pump keep tripping the RCD, it took me a while to work out how the other electrician had wired it but of what I see, it's a bit of a mess. I'll do my best to explain for the pool I can see 3 MCB's used 1st is a 6A type b in to a time clock in 1.5mm2 then that goes into a contactor then there is a 32A type c in 6mm2 that goes into the contactor then SWA to the pool. Then the last one is a 10A type c in 1.5mm2 that goes to a switch then in SWA to the pool to the plug where the pump plugs into, this is when the RCD trips. I've tested the cables and they are, R1-R2 1.32ohms insulation resistance is all around 100Mohms. Ze is 0.19ohms Zs is 1.21ohms PFC is 1.22KA and the RCD trips within the permitted times, the pump is PSH mini.2 50m 0.37KW. I've never worked with swimming pools before it's a bit out my comfit zone I'm just trying to help a friend. Also the pump works fine for hours when pugged into another RCD protected circuit.
Simon please respond ??????
You had great advice on your previous thread about this so what is the problem now ???
Do you have a swimming pool pump fetish.
Haha good one I've been in the trade a while now & I most defiantly did not go on a 5 week course if I wanted to spend ÂŁ8k I would of just gone to uni... I was an apprentice thanks
Simon,
just admit one thing. You are not competent to be working on any installation, never mind a swimming pool.
Your record on here hardly sparkles does it?
Find something else to do, Joe Public deserves that.
Simon,
The boss has spoken !!!!
Sound advice Tony
Reply to RCD trip out in the UK Electrical Forum area at ElectriciansForums.net
Hi, The RCD which protects my 16A ring main always "trips" when I plug/unplug a Laptop power supply. No other type of appliance causes a problem...
Unfortunately my electrician is too busy installing EVs so I've kinda been left on my own for now! I have an issue where the RCD labelled #1 in...
Ok, I've got an issue I can't figure out to save my life. Background: I'm putting in a 100a sub panel in my detached 2 car high bay garage...
Hi all - hopefully you can forgive my lack of knowledge on electrics, I have a basic grasp but am no expert. The issue I've had and am looking...
13K
