So the garage is without an electrical supply, so I decided to install one.
I laid about 20M of 2 core 2.5mm2 armoured cable and terminated it in the garage with a consumer unit.
Added a metal clad double socket again supplied by 2.5mm2 - all mounted on a large sturdy wood board and encased in trunking.
Ran separate trunking with 1.5mm2 to a strip LED light in the centre on the ceiling with a pull switch.
I tested the installation initially with meter and then live with an extension in the house run to a 13amp socket and it all worked perfectly.
I finally wired it into the main fuse box but now it immediately trips the RCD.
OK the obvious conclusion is that somewhere I have a leakage of current to earth BUT the aforementioned socket is wired through the main distribution board through the RCD. I have checked that the MCB supplying the socket is protected by the RCD - it is.
So the RCD does trip when it's supplying current through the socket outlet bit does trip when it supplies current through a new MCB.
Curious.
Any technical solutions please.
Curious.
