Discuss Rebating a consumer unit in a single skin wall in the UK Electrical Forum area at ElectriciansForums.net
davetherave1979
Hi Guys need to do a board change for a customer old fuse board is in a cornor of the kitchen, only way in is by going through the kitchen cupboard worst place `I have ever seen a fuse box. Want to mount the new 1 on the dinning room wall drill through from were old board is can I chase the single skin wall out and plaster in the back part of a mk board and then attach the cover after all the work is finished the wall is made of breaze block there will be no fire risk and all ip ratings will be fine will this be fine if not any ideas client doesnt want to see a fuse box on the wall and doesnt want to box it in after thanks
You need to select a CU that has been designed for that. I have installed similar and when done properly the cover fits over nicely. I think the one i used was a MEM, but have a look around cos you are going to need a really nice looking one if there is such a thing :)
As Lenny has pointed out, you could compromise the structural integrity of the wall and the building by doing this. Have you confirmed it's not a supporting wall? You may have to stick a lintel in?
if the house is less than 40 years old, it will probably collapse without fitting a lintel.
Reply to Rebating a consumer unit in a single skin wall in the UK Electrical Forum area at ElectriciansForums.net
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
