Discuss Relocation of electrical meter in the UK Electrical Forum area at ElectriciansForums.net
in order to facilitate the relocation of an electrical meter from the ground to 1st floor UKPN has asked me to install a what they are calling a read head cut out within the 1st floor by the consumer fuse board to facilitate their new electrical meter position which will be installed by another party.
What is a red head cut out and why does it need to be there?
I have only ever heard or redlink which is a solid fuse link placed in the Henley block when the main cutout fuse is in a different location
They look a bit like this, there's a solid link in the fuseholder which looks like a bit if steel pipe.
You occasionally get people (Electrical Trainee's and the like) who don't know what they are doing posting pictures saying that the DNO has bypassed the fuse and caused a dangerous situation when it is intended to be an isolation link.
I saw one of those today. There is no fuse in it, just a piece of metal which is dangerous so I have reported it to the DNO.
Reply to Relocation of electrical meter in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Hi all, Very much a novice when it comes to electrics. Anyway, we're getting an EV chargepoint installed, but before we do, I was wondering what...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
