Discuss Remote control operated outside lights in the Electrical Tools and Products area at ElectriciansForums.net
M
MRES
I am wondering if anyone can name me a manufacturer that makes floodlights that work via a remote control and/or a remote PIR with a battery in it. I know they exist because I have come across such a system a while ago however I cannot remember the name.:confused:
The system I came across had two remote PIR`s on the side of a barn conversion. The PIRs were not 230v but battery operated. Then there were three floods (230v) which had IR sensors on to recieve a signal either from the PIR or from the remote control (which the home owner kept in his car). The floods were switched on at night if a presence was detected on the drive way or could be switched on and off via the remote control. It was a pretty good system.:D
Thanks in advance guys.
Thanks Warren
I have been doing some "Googleing" and have found that Time Guard did but have now discontinued a range of equipment suitable to what I require.
I have spoken to my wholesaler and they can still get hold the range at good prices too.
Regards
Mark
Theres something we fitted a while back that might help you out.
What it is is like a mini board which you put a main supply to then has the option for four outputs which are operated by remote control. Have fitted a few now, mainly for outside, garden lights etc. Cant remember the name but got them from a shop called Mr Resistor in Putney.
This might work....
I've fitted a few of the Mr resistor panels. Not cheap c.ÂŁ100 or so for 4 circuits and each circuit has to be connected to the one receiver panel but wee buns to wire and programme. Ideal for garden stuff etc. Also came with a wall switch and a pocket remote control. The ones I've fitted have lasted prob free for a few years and I probably fitted them wrong a few times!!!
I've just re read that and an explanation for wee buns is it's a Northern Ireland expression for a piece of cake.
I got mine from the electric ctr womsleys , outside light remote control and wire free switch to go inside ÂŁ40 . easy to fit and set up
Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply. :)
Reply to Remote control operated outside lights in the Electrical Tools and Products area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Our electrician inexplicably wired outdoor floodlights attached to side of house over driveway as "always hot", no switch. We don't want them...
I've just changed the bulb in an outdoor PIR security floodlight (to LED). But the light stays on by default, and turns off when I go outside. I...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
