Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Discuss Remote control operated outside lights in the Electrical Tools and Products area at ElectriciansForums.net
M
MRES
I am wondering if anyone can name me a manufacturer that makes floodlights that work via a remote control and/or a remote PIR with a battery in it. I know they exist because I have come across such a system a while ago however I cannot remember the name.:confused:
The system I came across had two remote PIR`s on the side of a barn conversion. The PIRs were not 230v but battery operated. Then there were three floods (230v) which had IR sensors on to recieve a signal either from the PIR or from the remote control (which the home owner kept in his car). The floods were switched on at night if a presence was detected on the drive way or could be switched on and off via the remote control. It was a pretty good system.:D
Thanks in advance guys.
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
M
MRES
  • #3
Thanks Warren
I have been doing some "Googleing" and have found that Time Guard did but have now discontinued a range of equipment suitable to what I require.
I have spoken to my wholesaler and they can still get hold the range at good prices too.
Regards
Mark
H
hyperliteliam
  • #4
Theres something we fitted a while back that might help you out.
What it is is like a mini board which you put a main supply to then has the option for four outputs which are operated by remote control. Have fitted a few now, mainly for outside, garden lights etc. Cant remember the name but got them from a shop called Mr Resistor in Putney.
This might work....
jeremy
Mentor
I've fitted a few of the Mr resistor panels. Not cheap c.£100 or so for 4 circuits and each circuit has to be connected to the one receiver panel but wee buns to wire and programme. Ideal for garden stuff etc. Also came with a wall switch and a pocket remote control. The ones I've fitted have lasted prob free for a few years and I probably fitted them wrong a few times!!!
I've just re read that and an explanation for wee buns is it's a Northern Ireland expression for a piece of cake.
J
jim_jimmy
  • #6
I believe they are known as "wise boxes"
P
Phil
  • #7
I got mine from the electric ctr womsleys , outside light remote control and wire free switch to go inside £40 . easy to fit and set up
Dan
Admin
Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply. :)
Electrical2Go - Online Electrical Supplier
Reply to Remote control operated outside lights in the Electrical Tools and Products area at ElectriciansForums.net
Scolmore Electrical Products
Top Bottom
