S
spionkop
We recently installed a PV system for which our quote included for a Fronius IG Plus inverter that has a facility to transmit to a remote display. When placing our order with the panel and inverter supplier their technical manager suggested that we upgrade the inverter to a Fronius IG TL as being a perfect match for the system. We took this advice but now find that this transformer less inverter does not have a remote facility. It does have a USB port to download information but the customer would have to climb into the loft to obtain this.
Can anyone suggest a means of providing a remote (or even a wired) display unit for this.
Any help would be appreciated.
Thank you for your input BiggsSolar. We actually did purchase the Fronius Personal Display which we have previously used on the IG & the IG Plus inverters and tried to fit it to the new IG TL (transformer less) range available since July 2010. There is no PC card facility on this new range and speaking to Fronius technical support there is no release date for a suitable product. What we are looking for now is a third party system that will do the job in order to satisfy our customer.
Hi Spionkop, There is a Fronius Interface card avalable for the IG 3.6 TL. see below attachment& info
DIFRPDC
Fronius Personal Display Card Retrofit
£97.73
This can be obtained from hainesdistribution.co.uk at £93. Telephone 0333 800 2010.
You will have to check your IG 3.6 TL s/n just to confirm compatibility.
Regards Brian
I'm trialling this at the minute - DIY KYOTO — wattson Solar - available from Segen at a substantial discount. It measures what is being generated as well as what is being used so and you can dowload the info onto your pc - not sure if it will link with Google Power but sounds good in theory.
Hi KenHobbs, Sorry about that but the info I have from Fronius, is to infer all IG. Inverters, it does not mention a differential compatibility so its rather ambiguous!
Quote = Please note that the wireless display can only be used with IG inverters with serial number 14330071 and higher.
Many thanks for your information.Buying one of these could end up an expensive error.
Thank you all for your input.
We were talking to the Fronius technical representative at the recent Ecobuild exhibition who told us that a remote unit is being developed at the moment and reckons that it will be available in 'a couple of months???' This new unit will be more advanced than the existing personal display and will also be compatible with the existing IG inverters.
We will wait and see.
Regards
Bryn
Remote diplay for a Fronius IG TL 3.6
spionkop,
SolarCity,
