I think he is trying to find an excuse not to test it
As soon as the Sparky closes the door on his way switch will be back in the on postion, cut the seal and pull the fuse, how dare you Pet999 go stand in the naughty corner,Just do a proper EICR and submit out with your invoice ......
What exactly is the problem, just turn off the main switch on the fuse board
I’m not sure if my pink screwdriver set from Homebase are voltage rated?
are those rated to 1kV?Get some of these.... Job sorted..
Based on purely what you have said in the op - no.
Have you found a Reg to state that no live parts can be under the cover of a DB that is secured by screws?
How do you carry out EICR's if this DB is worrying you?
In the process of doing an EICR for a rental property (probably an HMO).
Really old CCU that has exposed live parts once the lid is removed and so would need to be super careful testing as there is no other isolation except the 100A tagged fuse.
Don’t feel comfortable doing any further tests because of the safety nature (am I a wimp).
But it occurred to me that surely this should definately be a new board upgrade job if it’s in a HMO property?
Thoughts??
