Discuss Replace a 25" electric baseboard heater with in floor heat in the UK Electrical Forum area at ElectriciansForums.net
Jeremy123
Hello
I am starting to plan a bathroom renovation and would like to remove an old baseboard heater and replace it with infloor heat. The circuit looks to be a double breaker 20amp each that runs to a baseboard in the powder room onto the laundry room then into the bathroom i want to replace then on to 3 more bedrooms. Each room has the same 24" baseboard. It is a 12gauge wire that comes into the existing thermostat and appears to have a 14/2 going to the existing baseboard and a 14/2 that continues into the 3 bedrooms. Should it be okay to replace this one baseboard with ifloor heat, and should i plan to use a 120volt wire for infloor or 240volt?
Thanks for any input on this. i have done a fair bit of small new circuits in the past for lights and plug ins, always with the correct permits and inspections. But i have never done anything with regards to baseboard heat other then replace old thermostats with new ones.
thank you
jeremy
Reply to Replace a 25" electric baseboard heater with in floor heat in the UK Electrical Forum area at ElectriciansForums.net
Im a DIY novice. I have changed central AC thermostat, light fixtures, switches etc. This has me stumped. I have a 240v single pole baseboard...
Currently I have a 20AMP breaker with 12 gauge wire going to a 15AMP GFCI receptacle in a bathroom. The receptacle is the only item on this...
Hi all, I have a slightly mish-mash heating set up, in that downstairs I have wet underfloor heating with an individual thermostat per room, but...
