Discuss Replacing 2 gang 2 switch light switch help in the DIY Electrical Advice area at ElectriciansForums.net
Rayhan
Hi guys
I'm trying to replace this light switch 1 with light switch 2. But the setup is totally differentas you can see and I can't work out what wire goes where.
Any help?
Light switch 1 has a dodgy button loose switch so needs replacing but I can't find a switch plate which matches the existing one.
Old broken switch 1 with wiring still attached
2nd pic is the new switch I'm trying to fit
Any help is much appreciated
Are we allowed to give wiring advice ?
This would be a 5 minute job for a 1st year sparks to change without too much trouble
You simply have a common feed in and out and two switched lives , it really doesn’t get any simpler
do it 1 at a time. 2 L wires into each of the 2 C (com) terminals. link com1 to com2. then the 2 remaining (switched L) wires into each L1 on each switch.
Thanks for your help guys, particularly Telectrix cos I followed your instructions word for word and I know have a very snug looking perfectly formed light switch.
Result below
R
Reply to Replacing 2 gang 2 switch light switch help in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
