Search the forum,
Discuss Replacing ceramic hob for induction - basic questions in the DIY Electrical Advice area at ElectriciansForums.net
my apologies for previous post (since deleted my admin). full of cold, sneezing, eyes dripping like a tap. could hardly see keyboard. thought i had cut it.
Reactions: DPG
Re#20 - fully magnetic pan or just magnetic base pan......
The majority of the magnetic interaction between the hob excitation coil and the pan is taking place in a thin surface layer at the bottom the pan's base. An alternating magnetic field does not penetrate far into a conductor and decreases in depth with increasing frequency of alternation.
The strength of the mutual coupling between the areas/regions on the pan and the hob coils reduces as they become farther apart so again the majority of coupling is to the base since it is flat and adjacent to the coils.
One can also visual that the base will 'shield' to some extent the upright sides of the pan thus reducing further mutual coupling.
Another consideration is that the regions in the sides into which are induced electromotive fields are shorter in dimensions or put crudely small circumference 'circles/bubbles of metal' ; the net electromotive force (emf) around such regions/paths is consequently of low value than in the longer paths/bigger regions of the flat base. Most of the magnetic/electric reaction then to the action of the exciting magnetic field is taking place in the base not the sides.
The large eddy current fluxes caused by the induced emf loops are in the base. And they flow in a thin skin region on the bottom surface. So because it is a thin conducting region the resistance to the electron flows/eddy currents is effectively higher than that of the bulk of the base; beyond the skin depth is in effect 'not used' for eddy current fluxes.
The base is then where the bulk of the interaction takes place between the alternating mag field and currents to flow in the skin layer. In the skin layer these current flows through the skin resistance produces Joule/Ohmic heating of the skin layer (IsquaredR). Thermal conduction of this heat through the pan and thence into its contents results in cooking.
I think the IH makers are working on even higher frequency excitation coils which would allow 'ordinary' copper, aluminium, non ferro stainless steel pans to be used.
The skin depth is approx given by :
What this tells us that the skin is thicker for materials with low permeability like copper and decreases in thickness with frequency. A thicker skin means lower R in IsquaredR so less Joule/Ohmic unless one can increase the size of the eddy currents by more powerful excitation fields.
Copper, Aluminium, non ferro stainless steel happen to be very good conductors and have very low permeability. To employ them usefully for IH cooking pans needs a higher frequency excitation field.
Skin depth in copper
FrequencySkin depth (μm)
50 Hz9220
60 Hz8420
10 kHz652
100 kHz206
1 MHz65.2
10 MHz20.6
100 MHz6.52
1 GHz2.06
Producing high power excitation fields at higher frequencies requires more expensive power electronics than using a lower frequency (20-40kHz) and demanding 'special' pans to be employed.
Briefly, ferromagnetism adds to a pan's goodness for IH because of hysteresis losses manifest as heat.
Or something like this - it gives you the gist of what is going on.
Reply to Replacing ceramic hob for induction - basic questions in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone, I've got a new oven and have a question about installing it. It's a 2.6kW 13A oven, and a cable from the 32A cooker circuit to...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
Hi all, I’m now ready to install my hob, I have a 32A MCB with 6mm T&E feeding a 50A rated switched supply at the worktop. The hob isn’t supplied...
Hi, we are replacing our old hob and cooker and I need a bit of help, to make sure all is safe. This is the oven and hob specs: AEG IKB64401FB...
