Deleted member 110848
Hi, my company is in the processing of upgrading lighting from fluorescent to LED. I am having trouble sourcing 1800mm x 600mm recessed panel light fittings. Is there anywhere that still has these sizes as all I can seem to find is the 1200mm x 600mm? How should I replace these units? All help gratefully received. Thanks.
do a lux/lumen calculation and use 1200 x 600 LED panels. you may need a few more than the xisting number of florries, but get it calculated first. as an example, we did a shop lighting refit. the 600 x 600 LEDs we fitted gave better illumination panel for panel, over the 1200 florries that we scrapped.
don't buy cheap panels ,their tend to bit you on the back side .if they start going faulty .
Deleted member 110848,
Toneyz,
