Discuss Replacing MK Consumer Unit. Main switch position in the UK Electrical Forum area at ElectriciansForums.net
Hello mates. i have an MK CU to replace. As you may know, the main switch in MKs is on the left hand side.
There's no way to replace the meter tails. Is there another manufacturer that has a left-hand main switch CU, or a flexible position option?
MK is in fact a well-liked option. However, Hager is a manufacturer that provides versatile position possibilities if you're seeking for alternatives. Their consumer units provide you the option of placing the primary switch to the left or right. You'll have more installation freedom in this approach. Hope that was useful.
Reply to Replacing MK Consumer Unit. Main switch position in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
