That was pretty much my question, would it need to be fully cured before dropping the pump ?
I assumed most resin joints had similar characteristics, the standard torpedo type
Yes obviously I will be making sure there is no strain on the wiringAlso worth considering is the fact that most resin joints don’t have any strain relief and are not designed to be under tension or flexed.
and yes, I know the jacket will be bonded to the resin and will provide some strain relief but if under constant tension the materials may creep apart over time.
I think you may have to speak to the manufacturers of the joint before assuming it is suitable for the application.
Anyone on thisWould a well pump running dry dry cause an RCD trip ?
Or would it be a waterlogged pump
