Discuss Rewire period house in the Canada area at ElectriciansForums.net
A
asys
Hi I'm looking for some advice.
I have just received quotations varying between £6000 and £9000 to completely rewire a thatched Period house in north Essex as follows:
4 bedrooms, 3 Reception rooms, Office, Dressing room, Dining room, Kitchen, 2 x bathrooms, Utility room, 2 x Outhouses
To include New consumer unit 2dble skts per bedroom and dressing room. 6 x dble skts per reception room and office. 10 x dble skts kitchen. Electric water heating. Power to outhouses. Two ring circuits(upstairs and down) 2 x new lighting circuits. Removal of old wiring. Upgrading earth bonding.
MK Consumer unit and accessories.
Are these quotations within an acceptable range? To my mind there seems to be a wide variance.
Sorry. I meant 4 dble sockets in the bedrooms. Is a £3000 spread normal? I had expected them all to come in within a few hundred pounds. How long would you expect it it to do the job? No one has committed on a timescale.
YOU WILL ALLWAYS GET VARYING QUOTES AS DIFFERENT OPERATIONS HAVE DIFFERENT OVERHEADS,IE A COUPLE OF BLOKES WORKING OUT OF A VAN WILL ALLWAYS BE ABLE TO DO IT CHEAPER THAN A BIGGER COMPANY THAT HAS TO PAY OFFICE STAFF ETC ETC .MAKE SURE YOU GET IT IN WRITING EXACTLY WHATS INCLUDED AND APPROX LENGTH OF TIME FOR JOB THEN YOU SHOULD AVOID THE DREADED EXTRAS.;)
this quote tells us very little about the construction and state of the property.
better to stick to a "local" who wil have a more vested interest in doing a good job. Also what spec fittings etc. And what are the walls made of?
Depending on how old the house is make sure the people carrying out the work are well insured, as if something happens and their not it could cost you a fortune to have repairs done. :eek:
16th Century thatched cottage. Timber frame, wattle and daub walls Most current wiring is exposed. Run long and down beams.
The house is 16th century, timber framed, thatched with mainly wattle and daub walls. All existing wiring is on the surface. Mainly clipped to the beams
House is 16th century, timber framed, thatched, mainly wattle and daub walls. Current wiring is exposed mainly clipped to beams.
Probably would have been around the 7k mark if I was guestimating this, but could easily go higher if the builing is a difficult one or lots of fancy lighting. Without more details - impossible.
Do quite alot of period houses and the quote sounds fair
You get more variance in prices on these places than a "bog standard" rewire as some contractors are more used to doing them and can turn the job round quicker and have experrience of the unique problems.
Doing a 3 bed 15th century house with a new build bathroom extension, all wiring to be concealed (the biggest headache), with full underfloor heating system. Won the job at 11k which 3rd lowest qoute in a range from 9 to 18k.
Reply to Rewire period house in the Canada area at ElectriciansForums.net
Hi all, I posted here some time ago asking for validation of a quote I received for a rewire. (10k assumed 60 points) And got some good advice so...
Hello. Homeowner trying to understand what is a fair quote for full rewire. We've had to tear the ceilings down as part of unplanned asbestos...
Hello, I am renovating a house. I am rewiring myself. I am getting an electrician to install a new consumer unit & test all my work. I'm looking...
  • Locked
5K
Hi, Thanks to anyone who reads this and offers any advice. Sold my house and the buyer requested an electrical inspection report which they...
5K
