Am about to change a consumer unit where the existing cables all snake around a window and up to first floor.
As the plaster here is also being redone i am looking for advice on best way to run new cables.
The main incommer is under a bay window and there is only a 2 foot column of wall between the window and main door to run all cables up to first floor (ground floor already in and concrete).
I would have to run cables left out of consumer unit for about 2 to 3 feet then up the wall between window and door.
How can i do this safely within regs so nobody puts picture nails etc through the cables later.
Many cables to run (10mm x 1, 6mm x 1, 2.5mm x 7 and 1.5mm x 3)
