Discuss Running outside lighting cables in render in the UK Electrical Forum area at ElectriciansForums.net
Stubby
Hello,
I'm looking to extend my lighting circuit outside of my house before I have the house re-rendered. some of the wiring routes will need to go up and over windows etc so some of the cable routes will be outside the permitted cable zones. I was planning to chase t/e into the wall and to protect the cable with the galvanised steel channel in the places where the cable is outside the zones. my question is, is an acceptable method of protection? Any help or guidance would be appreciated.
Just thinking out of the box. What about running the cable within 150mm of soffit and drop down to light? May be not possible if it is a double story wall but if it is a single story wall, maybe that could work? Personally not done this way and would rather run inside and come out to light. But if customers don't want internal work, maybe the way I stated could be possible?
Don't use t&e outside like tel has said.
Thanks for the comments. Running cables inside is not possible as all the interior is finished to a high standard and I cant see a neat way of getting the cables routed. Unfortunately I cant go up to the soffits as it is a double storey property. Does the 150mm rule apply to around window surrounds?
Cheers.
Cheers.
Why not refer to your copy of Bs7671?
Reply to Running outside lighting cables in render in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi all, Curious one and hopefully some one of you could give me some advice. A customer has had a steeltech shed installed at their premises. A...
