Discuss security light woe's in the UK Electrical Forum area at ElectriciansForums.net
T
tube's rule
Hello everyone, wonder if anyone can help me with this, I,ve just installed two outside pir security lights on a 5 year old extention to an existing switched feed from the downstairs lighting circuit, nice neat job, they work fine,
two days later i get a call, "when you switch off the downstairs toilet light the outside lights come on" i go back when its dark and guess what, every 1 in 5 times(ish) you turn off the bog light the outside lights come on, this only happens with the bog light tho, does anyone know what it is or any idea's :sweatdrop:
Nothing wrong with being on a switch as such, but it needs to be one which is left on permanently, unless as already said, you need to override it by switching on and off so many times within a few seconds.
Are you a DIY'er?
The extension was only 5 yrs old, dear me. every day a school day i guess
I have a PIR light on the outside of my shed which, although wired correctly to the permanent feed of the lighting circuit, more often than not comes on in 'manual override' mode when the shed's twin fluorescent is switched off, so it could well be interference from something in your bathroom.
I had same trouble but flourescent was in customers kitchen and though not everytime when kitchen light was switched on one of the pirs outside came on. I swapped the starter in the fluorescent and it cured it. the starter was a like for like and not electronic.
If you're having a problem with PIR operated security lights, you need to chat with a bloke called Top Cat. You'll find him on "the other forum" and he knows ALL about them. :yes::wink_smile:
Reply to security light woe's in the UK Electrical Forum area at ElectriciansForums.net
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
Hi guys, medium to beginners experience in electrics. I placed a 250w security PIR light outside. I connected it to the inside first-floor...
