R
Richard3009
Mirror on permanent supply does it's transformer require local isolator in bathroom.
For fixed appliances in a bathroom the isolators are normally fitted outside the bathroom, obviously inside the bathroom is not an option.
Now you just have to consider whether the mirror you have is a light fitting or a fixed appliance to establish whether it would require a local isolator.
Normally I would take a lighting feed to it without an isolator, the same as you would for any light fitting which requires a permanent live.
As far as I know an airing cupboard is not acceptable for isolators for bathroom equipment.
Local isolators need to be easily identifiable, near to the equipment etc.
If you were to fix a visible label to the equipment detailing the location of the isolator this may be ok but would you wan that in your bathroom?
SELV LED mirror
Richard3009,
Richard3009,
