Hi All
A while ago a customer asked us to move a 1970s single phase corn mill and return it to use.
It had an old series parallel starter with a lever on it ..which we replaced with a crompton controls series 3000 starter...all good and running.
Now they had another ip rated box attached to the original starter with a 230v relay and a brodersen unic xw electronic timer (release delay,on pulse,off pulse,on off pulse) plus a 230v 2 wire proximity sensor on the mill hopper....they said it was used to switch the mill off when the corn ran out to prevent damaged rollers and they would ideally like it reinstated.
Problem was this stuff was bypassed when we got to it (the proximity sensor was found to be u/s).. and we have of course changed the starter to series 3000.
So I have done a couple of drawings .. but I can't seem to get it to work.
I'm thinking that the xw time delay is there to start the motor via the relay and get it milling until the proximity sensor see's the corn ...holding on the relay itself.. then drops out leaving the proximity sensor keeping it running ... when the proximity stops seeing corn it drops the relay stopping the motor.
So... am I on the right track here..can anyone give me a sketch for this..?..I can post more details on each item if required as I have the series 3000 diagram the relay diagram the unic xw diagram. .the proximity sensor is just 2 wire..
Cheers
Vito
Cheers
Vito
