Discuss Shallow depth ground lights in the Electrical Forum area at ElectriciansForums.net
R
Rauer
Hopefully someone can suggest some that they've used,
i am putting some decking down near my shed and I want to put some lights in the decking but I don't want the little piddley type ones , I want the bigger ones( like gu10 sized ones) but here's the problem I only have about 75mm to play with on the depth , ( concrete base is below) I don't mind chasing it out a little but would rather not, I am kind of gathering that I am looking at led due to the depth
ROBUS - Product Detail
Here you go... Not gu10, think you will struggle with size there. But these are a decent mains light. Fitted quite a lot of these in decking over last 5 years or so and haven't been called back yet for dodgy one yet..
well...i`v known myself to be shallow at times....and not always too light either....or is that bright?..
Reply to Shallow depth ground lights in the Electrical Forum area at ElectriciansForums.net
