Discuss Should I carry out EICR the change DB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
hello guys
Just want some advice as a landlord has sent me some pictures and the board defiantly needs changing and they want an EICR.
Am I overdoing it by carrying out an EICR with a fuse board to be changed which will get an install certificate or am I just sensible to carry out the EICR and have a board change as part of the repairs?
I only ask because they will get an install cert which could override the EICR once I change the board although an EICR is more sensible because I won't have any supprises once i change the board (should not).
The OP does suggest that a CU change will be part of the job ....
so its an EICR and a EIC ........ and depending on how you approach it, maybe another EICR..............
Job's not done until the paperwork is finished, as an ex Civil Servant I should know.
At the end of the day, you have been asked to complete a report.
I would carry out the EICR and list any remedial work. You then quote separately for that work.
You will still have all the test results and inspection details so the second cert (EIC) will be a doddle if you change the C.U
Reply to Should I carry out EICR the change DB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have an new set of circs here... Landlord in Cyprus EICR needed in empty flat. No credit on meter. Need power for Ze (TNCS) and RCD test at...
Good Afternoon All Currently doing an EICR on common parts of a big site with multiple blocks. All blocks have outside garden spike lighting in...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hey guys, Im starting to put my company out there more. And this is all a new journey for me being an apprentice and now being qualified/2391-52...
Hi all, Been asked to quote an EICR on a fairly large installation. Approx. 400 circuits that are a mixture of single and 3 phase. This is across...
