Discuss shower Pump in the Australia area at ElectriciansForums.net
smithjim0001
Shower pump fed by a fused spur.
Fused spur fed by 2.5mm load side of fused spur feeding shower pump with 1.5mm flex.
pump is 2.5ka so roughly 10amps flowing.
I would then think that 1.5mm flex can take up to 15amp free air so it would be ok to put a 13amp fuse in the spur
Do you all agree that 13amp fuse is ok.
2.5kW pump?
I have just installed one of those for a golf course irrigation system:D
I am assuming you are in an airing cupboard and are spurring from the immersion circuit for the pump?
Reply to shower Pump in the Australia area at ElectriciansForums.net
L
So my old man is planning on setting up a fish shed which will hold 2-3 fish tanks. The power drawn from the equipment which will be running in...
Just had three split Air Con units installed at my home, the ones with an indoor and outdoor unit. I (perhaps naively) trusted the installers...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
