Currently reading:
Signing Off An Electricity Certificate
Discuss Signing Off An Electricity Certificate in the UK Electrical Forum area at ElectriciansForums.net
O
OldManJohn
Can anyone tell me what the law is in regards to signing off an electricity certificate.
Does the person signing off the work and signing the appropriate certificate have to be associated with one of the electrical authorities e.g. NICEIC or can they be just a competent electrician not affiliated to anyone?
John
If the work is domestic and notifiable it can be signed off by someone who is enrolled with a competent persons scheme or notified to the local authority building control, in the later case the LABC need informing prior to the work being undertaken. Oh and they charge a fortune!
There is no law
The general answer is no,you need be a member of none of them
The IET publish the various certificate formats required by electrical contractors and everybody else,Niceic,Napit Eca ,you, me and Bert from Birmingham make up our own, based on the genuine article
The add on to the above is the demand of the client
If they specify that obnoxious organisation the Niceic then that's what needs to be provided
Hang on hang on, any electrician or technically competent person can test and provide a certificate.
Notification under part P is a separate issue, achievable by membership of a part P scheme or directly to the LABC office.
EDIT: What he said ^
Very true Andy, the only part of your post I would change is "can",I think "should" would be more appropriate
Judging by the OP's earlier posts it would seem that he's seeking clarification to talk to his builder/sparky about.
Is this right?
Ah,the penny drops
It does seem like he has the problem of engaging people to do electrics who are not competent electricians
When,or if ever will the public learn to respect electricity and stop using muppets to do the work
John,you have problems because you did not follow the law regarding building regs,in your case the section called
Part p,
Certification of electrical installations and procedures for conforming with building regs are 2 different animals
It's just that certification can be used to show you conformed to some requirement of building regs
Next time you have work done on your electrics,best to get someone who has been recomended by a friend or past customer, never believe that membership of a scheme is assurance of competence,this trade has become a add on for so many other trades who think they can wire
And never believe any one who says it doesn't matter.
I've now got a good business from people selling their houses who's solicitors are demanding certificates or EICR's to prove safety.
Ah,the penny drops
Part p,
And it goes further than domestic work.
There has been more than one occassion, where I have witnessed poor and even dangerous extended works within perfectly good commercial installs.
The company have called in bona fide, registered approved electrical contractors.
Who have then seen fit to send out some spotty faced 19 year old kid to have a go at works that really needs to be covered under supervision.
Its not the kids fault. But for sure it does mean that even if a registered company is used. Its no gaurantee that the man on the tools is up to the task.
I advise all companies seeking electrical works to get the measure of who the contractor sends. And ask to see there quals ie JIB gold card or similar.
Dont just let them loose on you premises.
Sad but true, and I know there are many of you guys who have seen the same.
Reply to Signing Off An Electricity Certificate in the UK Electrical Forum area at ElectriciansForums.net
