- Reaction score
- 4
Afternoon all,
I've had another clear out. I thought I'd offer it up to you guys before I whack it on eBay. I'm ideally looking for an offer on the lot, however i'm happy to take offers to suit what you need.
Here's what's available:
1 x Single phase 11 way consumer unit 100 amp incomer - M2 AM2X11MU complete with rear knockout spacer frame to suit.
1 x Single phase 2+5+5 RCD consumer unit 100 amp incomer - M2 ACP55CM2XMU complete with rear knockout spacer frame to suit.
1 x 1 x Single phase 3+3 dual RCD 100 amp incomer - M2 ACP33CMU complete with rear knockout spacer frame to suit. This has never been installed although there is a frame and metal tails gland already fixed to it - used as a sample/display model.
1 x 1 way TP distribution board - Proteus TPXMC1
1 x 2 way TP distribution board IP65 - Proteus
1 x IP enclosure 140mm Wide x 250mm High x 100mm Deep Proteus
13 x sheets of consumer unit stickers up to 16 ways
17 x sheets of consumer unit circuit detail up to 12 ways
1 x metal tails gland 40mm - Wiska
1 x plastic tails gland 40mm - Wiska
4 x M2 100a mains incoming isolator (twin and round terminals)
1 x Federal Electric HCA1P20 C20 SP MCB - Used
2 x Federal Electric HCA1P32 C32 SP MCB - Used
19 x C16 DP MCB - Proteus 21016/3
2 x Proteus/M2 full module blanks
4 x C40 SP MCB - Proteus 1040/3
1 x B6 SP MCB - M2 M2B6
1 x B6 SP MCB - Proteus 606B
2 x B16 SP compact RCBO - M2 M216MBRSPK
1 x B6 SP compact RCBO - M2 M26MBRSPK
1 x C32 SP compact RCBO - Proteus 32MCRSPK
1 x C10 SP compact RCBO - Proteus 10MCRSPK
1 x C32 SP standard RCBO - Proteus 32MCRSP
2 x Crabtree 80a DP RCD - 380/S030
1 x Schneider RCBO C type 16a - QO116C10RCBO30F
1 x Schneider RCBO C type 32a - QO132C10RCBO30F
3 x twin dry line box
12 x single dry line box
1 x single deep dry line box
1 x twin deep dry line box
1 x circular dry line box
Will send on a courier if need be. Photos to follow.
Cheers
Cheers
