G
GT1
Need to source 2 of the following.
Single throw relay (don't need DPDT)
Any input voltage, but 12v DC preferred.
Very low switching output of 3volts.
On energising the relay they need to switch over the 3volts for about half a second or so but then remain off until relay is cycled off back to on.
they are available from RS if I fancied buying a hundred at about 50 quid each !!
Just posting on the off chance anyone has any in the back of a shelf. !
Failing that I may have to take up amateur electronics and build a little pcb board from scratch !!
Single shot Relays required
Australia
GT1,
Knobhead,
