Discuss SMD LED porch spots all started flickering at same time in the UK Electrical Forum area at ElectriciansForums.net
Jane17
Hi hoping someone can help me...
I have 3 SMD LED spotlights in my porch & all 3 started flickering yesterday- I have an on/off switch no dimmer & they had been working fine for over a year...
Originally bought from B&Q but no longer sell them
Why would all 3 start flickering at the same time?
& what do I need to buy/replace to get them working again?
Are they all on their own transformer, if so likely loose connection somewhere.
If one transformer for all three then either loose connection or transformer failure.
There's always other possibilities but these are the most likely, imho.
Thanks GBDamo - yes they are all on the same transformer... I shall try replacing that before the spotlights
any constant current driver with a rated output of > 1.2A and voltage >13V would do.
Have the polarity been checked
on a second look at OP. it would appear that each light is 1.2A @ 12V, as there are 3 lights, that's 3.6A in total, so it seems that the driver is undersized.
some thing doesnt add up ?
4.5w @ 12v is less than 400ma
where does 1.2A come from ?
unless it's for three or four lights
either way a replacement driver will be available
Reply to SMD LED porch spots all started flickering at same time in the UK Electrical Forum area at ElectriciansForums.net
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
I bought a ceiling fan with LED lights. After some time the led lights started flashing when I put them on. Now it does not even jump up anymore...
