Discuss Socket height in summer house in the DIY Electrical Advice area at ElectriciansForums.net
Hi everybody I would like some advice on the height sockets in a summer house am I right to say they need to be 450mm from ground cheers Paul
Is the summer house a new build?
You can have the sockets any height that you want.
The 450mm height malarkey is Building Regulations part M which relates to disabled access in new build houses. Not garden buildings.
but what about his garden gnomes. how high can they reach?
I know this question has been done to death but can't find the posts. What if you extended your house and the old part had sockets under 450...would new sockets need to be at the stated height or could they match the old part??
It’s up to the householder.
Part M is just an attempt to standardise new builds.
Depends if the extension was under building control supervision. Then it depends, in my experience, on the personal opinion of the BCO.
Is that ground level or finished floor level?
If they were to insist on socket heights like that, they should also require the other items in part M
doors of wheelchair width
access ramps
etc
etc
Part M only applies to HABITABLE ROOMS in VISITABLE DWELLINGS
a Summer House is not a HABITABLE ROOM as defined in Building Regulations.
Part M defines a habitable room as a room used, or intended to be used, for dwelling purposes including a kitchen but not a bathroom or utility room.
A "dwelling" is defined as
A self-contained building or part of a building used as a residential accommodation, and usually housing a single household.
A dwelling may be a house, bungalow, flat, maisonette or converted farm building.
(Not a summer house then)
So, planning or not, any BC geezer that tries on the 450mm socket stuff can get raffled. I know, I have defeated them on this exact point.
Reply to Socket height in summer house in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I recently moved to an older property that had a run down garage. We had this removed and a summer house put up in its place. The old...
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hi all. I've recently bought a bungalow. It currently has a armoured cable between the house and garage which spans less than 1 meter. The height...
Hi all I would like to put some sockets in the attic and keep them on the main house ring main. Am I right in saying I can pull one of the legs...
