Discuss Solar iBoost and new Immersion Element in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
S
SirV
Thinking of adding an Solar iBoost to my home system but also changing the immersion heater as its been in for about 14 years and no doubt heavily covered in limescale, not even sure it has a thermostat on it.
I noticed that Backer do specific low wattage immersion heaters for Solar. Is it worth getting one of these for use with the Solar iBoost or go for a normal replacement as the Solar specific ones seem expensive.
Thats what I thought. I did not really understand why I would need to buy a low energy immersion when that Solar iBoost should be handling how much is sent to it anyway.
It is quite a clever unit really. It is not a simple on / off switch. It ramps up and down with your PV export upto a maximum of 3kw. If you override it with the boost function when the PV is exporting less than 3kw it delivers the full load to the immersion with the extra power required made up from the grid.
Reply to Solar iBoost and new Immersion Element in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
Hi All. Its been ages since I have been on here- Fortunately log in details stored on PC. I have just had a new boiler and 210 ltr unvented tank...
