Discuss SPD in a plastic consumer unit. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Pat H
Adding an EC charger and looking at options to include an SPD.
The consumer unit is plastic (but in good condition)
Options seem to be to add an SPD (with isolator and MCB) before the consumer unit.
Or add an isolator before the EV charger with an SPD, isolator and MCB.
Or can an SPD be added in the consumer unit?
There is room in the consumer unit but as it's not metal (so not 27th ed) not sure that's allowed.
I can't see any real reason for not being able to add an SPD internally to the consumer unit, as long as it's not going to make it any less safe.
This maybe worth a read
Reply to SPD in a plastic consumer unit. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi, I have a property that I was looking to rent out. Its 12 years old property so relatively new. I had a EICR done from a qualified electrican...
6K
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
