Discuss Split Charge system fitting help badly needed in the Auto Electrician Forum area at ElectriciansForums.net
Lexlee
Hi ,
I have aquired a split charge system believe it to be from a Network Rail van. I'd like to fit it to my Landrover Defender (1995). Unsure as to what main wires go where as in starter battery and leisure battery, I've posted a pic of whole system and some of individual parts . I have labelled the main wires 1-5 so if anyone can offer any advice I know which wire they are talking about. Some cables already fixed as can be seen in pics others are loose
Cable 1 fixed on end loose the other
Cable 2 same
Cable 3 neither end fitted
Cable 4 fixed one end loose the other
Cable 5 neither end fitted.
Once I have the info as to correctly wire up the main battery cables I should be OK to figure out the rest,, Fingers crossed.
Or if anyone has any information regarding this set up that would be a great help, I mean massive help.
Split Charge system fitting help badly needed ima - EletriciansForums.net
Reply to Split Charge system fitting help badly needed in the Auto Electrician Forum area at ElectriciansForums.net
