Q
quattro64
I have a job comming up where I need to run power from the house to an outbuilding into a new consumer unit and then from this building to another where there will be a smaller consumer unit. I have completed my calculations and the cable leaving the house will need to be 25mm and then 16mm on to the second smaller con unit.
Where the armoured supply comes into the first building, I was going to split it using a 3 way Pratley box with one line going to the first consumer unit and the other going to the second via a fused switch. Could someone confirm if this is a sensible way of doing it or suggest a better / easier alternative?
Many thanks in advance.
