steviethespark
Has any one installed spots lights above a pot belly stove ,my fear is the heat will affect the led spots and even to a certain degree the cables may get affected above the ceiling Im installing a small mf ceiling to allow for spots I have attached a pic of setup minus mf celing which I will install a lowing 85mm void for spot .Any help appreciated guys
Depending on the distance from the stove, over 1m should be OK unless very enclosed.
The cables should be selected for a higher ambient temperature and rated accordingly, but otherwise should be unaffected (unless the ceiling burns!)
LED lights may well not like the higher temperature and have a reduced life, in this case I might recommend halogen spots as they will be OK.
Spot light install above a pot belly stove
steviethespark,
Andy78,
