Discuss stainless finish switch plates in the UK Electrical Forum area at ElectriciansForums.net
A
amckay
I've just put up a stainless switch plate.
The plate itself is giving me a reading of 10-12v.
Its earthed, and I've disconnected the earth just to see if any difference in voltage but there isn't.
Checked cables, no nips on insulation, nothing touching back box, its not tripping RCD, even when I touch the plate.
I'm just wondering where this 10v is coming from.
Any ideas on where to start "faultfinding" on this one?
Trench dug, tin hat on.
Try testing with an analog meter, and see what reading you get then.
I'd put money on it as being 0V.
Inductance/capacitance/earth leakage at an accessory will all give a very low reading with a digital meter. There are volts there, but no amps (ok, it is such a very low milliamp current that any analog meter will not be able to read it)
I thought he was talking about an old style analog voltmeter, similar looking to an analogue IR meter.
I have a cheap digital pocket multimeter already, I'll pick an analogue meter up cheap from amazon I guess!
10-12 volts between what exactly?
Sorry Pete and snowhead.
10v was measured between two parts of the plate.
I got 236v from line to neutral and 12v between line and CPC.
It just seemed strange to me so I thought I'd ask you lot as I'm not exactly full of "experienced" lol
Surely if you work for an electrical testing company there must be someone who knows the appropriate tests to carry out? Daz
Reply to stainless finish switch plates in the UK Electrical Forum area at ElectriciansForums.net
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
The previous owners of our property had non in ground rated electrical hardwired into the basement from an outdoor submerged pond fountain...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
