H
highspark
Having problem with a PIR. It's only supplying 1 x garden light @ 60w. Very small load. Basically sensor is switching over fine. However the light is illuminated constantly very dim. Once PIR kicks in it goes to full brightness. Though I had faulty sensor took it back and swopped it.... Same problem. Connections are Live in, live out and neutral.... Any idea's?
Sounds like semi conductor (triac).....suggest switching a relay or contactor via pir first, then used the relay/contactor to switch the led fitting.
A lot of messing about if that's the case... Will prob just take back and get one with relay.
areyousureit'snot afitting that illuminates dim when dark and bright when triggered.
he's been banned, but nobody knows why, i've not seen any offensive posts by him.
He was being a tad spikey last night, it doesn't seem to take much these days. I don't think the kind of general workplace banter is tolerated on here. He didn't seem the sort to tolerate fools easily, so maybe not the best arena for him.
