having to unscrew the cover off your supply box is dangerous and contrary to regs, you are not a competent person to be accessing area of live cables. your park owner needs to fit windows to your box so you only need to lift the flap to reset the switch
William, you already understand what's going on; Your 16 amp MCB is always going to trip before your 32 amp one. You know that.
In the long term your solution is to fix your boiler because heating by daytime electricity is very expensive - as I sure you have found out.
In the short term you could put a 16 amp MCB in place of the indoor 32. It may trip before the outside one because it's in a warmer environment and this is thermal tripping not magnetic.
If it's going to be a long time before you can fix the boiler then buy a couple of cheap electric storage heaters. You wont be able to access cheap electricity because you don't have the right meter but you will be able to run them at night when everything else is off so your peak current will remain under 16 amps.
Hope that's of some help.
Laurie
I have 5 static vans on a site on the coast in Mid Wales. When the site first started in the 60's the only things electric on a caravan were the tail lights. Since then caravans have got bigger, you can get 28' x 40' lodges now. These are bungalows on wheels, the only things gas in them is the hob and central heating, the rest is electric. When the original site infrastructure was installed it wasn't envisaged what caravans would become. When the site reopens in March most of the owners will be there to open up their caravans, as it's still cold we will all turn on our 2Kw electric fires and lights and TV's and our kettles and phutt. Last year we took out the whole village. This year the site has invested in some generators so we shouldn't have that problem again. To upgrade the infrastructure would cost a fortune and it would be the owners that pay for it in their site fees. So juggling what you switch on and when is a cost affective option, it's sometimes a pain in the butt, but C'est la vie.
In the long run, the money the site paid for these generators, the fuel running costs and the maintenance of these generators, it would have been better spent on the power infrastructure. Running a 40' X 20' on a 16A supply all year round is just ludicrous in the UK!!
