Discuss Strange fault in the UK Electrical Forum area at ElectriciansForums.net
I think Tel has a very good idea there, you can buy a simple '1 module' 20 amp contactor for not much money then feed the coil from the linked PIR switched live, you can mount it in a simple plastic 2 module enclosure with a blank over the spare 'way' which will give you plenty of wiring space.
I agree. It's a good idea
Reply to Strange fault in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
A BG fused connection unit, with neon. A boiler. Fuse out. Spur switched off. I was checking polarity after a colleague had 2nd fixed it and...
