Discuss Strip lights where spot lights were. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Have three spot lights in wardrobe.
Wired back to switch.
Wanted to take out the three spots and replace with one strip light.
The strip light is currently wired with a figure of 8 lead to a plug. 2.5/250 would it be correct to be able to strip off plug and wire this to where it current wires to the spot light.
Light.
should be OK. long as you're competent to do it safely.
The strip light is mains voltage. Are your spotlights also mains voltage, or are they 12v?
If they are mains then you can connect up. If they 12v then you will have one, or several, transformers hidden somewhere that will need to be removed.
Reply to Strip lights where spot lights were. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi everyone, I'm hoping someone here can help. I recently did some carpentry work for a new customer and I noticed their electrician had just...
Hi, I have replaced some under cabinet kitchen tube lamps with LED ones. I followed the same layout and just replaced the lights. Each light (4...
