L
Liamsparks
Hey guys, had a phone call from a local building firm.
Want me to price for a new garage install but i have no infomation on how many sockets/lights.
phones the firm they said they'll discuss with the customer what he wants etc but they want a price off me "per light, per socket" prior to that.
but how do i price not knowing how long the run is how much cable i'll need if i need to rcd protect the board or just a small garage board fed from an RCD inside the house.
He said it'll be something along the lines of:
2 x lights
2 x sockets
1 x water heater outlet point
1 x fan
so i can probably get away with running a 6mm2 i'm just stuck on how to price it without out knowing what is exactly wanted or seeing the job....
Need it to be done by the 13th May.
Ask the builder for a price on building the garage with the same level of info and see what they say!
When they ask for more info ask for a price per block, etc. and see what the answer is!
ask to see building plans, current level of installation rcd protection, bonding, is it a stand alone garage or attached to house, what type of lights
just bombard with a million questions then say well it would be easier to discuss in person and meet with them
is it the quote needs doing by 13th or the work cos that is some tight schedule
2 x lights
2 x sockets
1 x fan
Tell him you need to see the job, or give him an estimate and tell him "it will be something along the lines of £200 to £1000".
Cheers........howard
Builders probably worried you'll spill the beans over the true cost of the job to the customer and he won't get to mark it up, maybe:p
Its all being delt through a property management company, been on their site they got quite a big portfolio, thing is if i do this one good enough i could get my foot in a nicely sized door!
Cheers for info so far guys
...i do this one good enough i could get my foot in a nicely sized door! ....
Good enough or cheap enough? And you want more jobs to price like this one? What do you think happened to his last electrician?
IMHO There is always someone ready to under-cut a quote and it sounds like he's fishing for just that. If you really want to go for it, work out costs for what you think will be worst case scenario (chances are it will end up worst case anyhow by the sound of it) and stick to it. If you win it you pitched it correctly you are quids in and can look forward to a profitable future, if you lose it, see it as a lucky escape, Chances sre he will be fishing again soon when his latest electrician has had enough. Good luck.
When I get these type of no info estimates to do I give a price based on my list of assumptions listed on the Est eg 2 sockets,2 5th fluoro 10m 6mm saw from cu mcb to 3 way garage rcd cu. Current bonding and earthing needs to be to bs7671.
That sort of est covers you and they get a price.
