C
cairns
Hi all,
Just wondering if ifs ok to use 1.5mm SWA armoured cable on a wendy house with a 25m run from the board to the wendy house on a 20 amp breaker, its only gooing to feed 3 double sockets and a couple of outside lights, nothing extravagent is going to be used on the sockets, just wondering as my cousin has a load of 1.5mm SWA. I'm thinking it may be better to use 2.5mm SWA however???
Cheers,
John
id say no although the distance is only 25 meters minimum size for a 25 mm run would be 2.5 mm 3core on a 20 amp mcb, but ill be honest i tend to over rate my cables and put a 6 mm 3 core with a small 2 way CDU so you can protect sockets and lights from in the wendy house
SWA cable size to a wendy house
Australia
cairns,
cairns,
