Discuss SWA outer armour not earthed at either end. in the UK Electrical Forum area at ElectriciansForums.net
Fitzy
A friend at work asked me to take a look at the electrics in his shed, RCD would occasionally trip out, turned out to be a very loose neutral going in to the RCD.
One thing I did notice though was that the 10MM2 SWA entered through the back entry point of both the shed & house CU and neither end of the outer sheath was connected to the earth bar and was also very loosely pushed through at the shed end directly from outside of the shed. I thought that the outer armour of the SWA cable had to be earthed at at least one end, if not both? Am I right here?
Yes, it should be earthed, preferably at the supply end.
So one end is ok then?
I was thinking of adding the brass gland to the supply end, then run an earth fly lead to the cu early bar, is this ok?
Plus, is ok to use the back entry for swa cable, or should it always be glanced at both ends?
Is there a core being used as the cpc inside the SWA?
The armour should be earthed at supply end at least.
10mm? What the heck has he got inside the shed?
or is that, what the heck is he growing inside the shed?
Yes, the black core has been used as the earth, the house’s supply is TN-S and the SWA run is roughly 30m in total. One light circuit and 2 socket radials in the shed.
Is it ok to go directly in through the back of the db, directly from outside? There’s been no mastic used to fill the rear entry hole either. I would’ve clipped the swa to the inside wall of the shed, then in to the db.
I would terminate into a wiska/adaptable box fitz and then from that to the Cu in t&e
I did suggest re-routing the swa to the inside wall, then glanded in to the shed db, luckily there’s enough slack in the swa to still reach the db from inside, then i’ll fill the hole in shed wall.
It was only done last summer by an electrician friend of a friend.
Reply to SWA outer armour not earthed at either end. in the UK Electrical Forum area at ElectriciansForums.net
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
4K
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi all Now being upfront I am not a sparks. I am about to have some work done by a friend (certified) and as he is doing me a favour I want to as...
