Discuss SWA, T&E or tails?? in the UK Electrical Forum area at ElectriciansForums.net
wrong reg states not readily combustable so unless you coat the plastic in parafin it complies
No it doesn't. It states "non-combustible" - the "or not readily combustible" part in the Draft for Public Comment never appeared in the Standard.
Everything can given sufficient heat!
I'm not a scientist, but I think that when metal is heated to a sufficient temperature it changes from a solid state to a molten state. If it's heated to a higher temperature it may actually boil and turn into a gas. To catch fire, is a state of combustion. If metal can be combustible, then it's not gonna be much use as a material for 421.1.201. :)
I've used a few of these to supply submains etc & I agree top value and a decent quality unit,but I've been thinking...what about amendment 3? they don't comply eh?
I would say that they do comply when installed in an external meter cabinet as long as there's a fireproof wall between the cabinet and the inside of the property.
Reply to SWA, T&E or tails?? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
Client has had a meter installed for a new consumer unit in their shop they are looking to rent out the spare space for a barber shop so they want...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
