Discuss switch wire I D in the UK Electrical Forum area at ElectriciansForums.net
hi guys,
just having a debate over switch wires not being marked up,
one guy says its a code 3
one says if you don't understand what the cable does and where it goes you should not be in the fitting in the first place.
care to comment guys
I expect to see it in every installation I arrive at to be honest, it's that commonplace. Yes, a code 3 on an EICR too.
thanks Andy78
the scenario of the ID switch wire came up after my friend changed a light fitting on a new build and found no ID on the switch wires,
NIC registered install too
Its a requirement now if the cable is not of a phase colour (earth conductors not to be used for L or N of course), so as you testing to the 17th you will need to code it as suggested, yes also you colleague is correct you should be suitably competent in the first place but the regs are designed to reduce confusion and accidents and this is one area DIYers often balls up as well as the less competent sparks.
When you say ID are we talking about marking up the black (old colours) or the blue (new colours) with a sleeve to identify it as a phase conductor?
I can see both sides, we used twin red (old colours) on switch drops with t&e or sleeving red/black, brown tape would not be a fail?, it's been id. thoughts.?
...Must be a slow news day...if i have to comment,it would be to say how disappointed i would be,if i read a previously completed EICR,with code 3's for missing cable ID's,and everything important Limmed out...
If more people would buy the correct cable ie. twin brown PVC/PVC or in old money twin red PVC/PVC then this problem would never be an issue. Always wondered why this is not normal practice on the mainland.
A tagged blue gives more information at a glance (i.e. which is L & SL) than twin brown. The browns might be different but not so obvious.
hi guys,
Oh no------------
Reply to switch wire I D in the UK Electrical Forum area at ElectriciansForums.net
I have 2 kitchen lights, each on its own switch. I would like to re-wire them to where the first switch turns on both lights, but where if the...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
