Most likely like jack described a district system. Usual setup is biomass boiler feeding buffer. From buffer to district pump.One district pump I should imagine with only feeding 2 houses. Pending on manufacture of boiler, all these can be wired back to boiler and controlled via biomass boiler controls. Treat the heat exchangers in the houses as conventional boilers and usually wired as S plans supplyed from local supply.
I would expect this system also boiler feeding buffer tank in feeding to house heat exchangers 24/7 regardless of property demand. Each property then drawing as required from heat exchangers on demand from house heating controls.
The pump is being run independently so that there is minimal disruption to the controls at each plot as it is existing houses with heating systems already installed. Forget about the boiler and it's set up completely. All I want to do is have 4 independent circuits that are able to switch a two port valve at each plot which then brings on a pump when called upon from any plots.
Just an idea, could you fit a precision flow meter with an output signal or flow switch so when the pumps inside each property kicks in when calling for heat the flow switch/meter detects the flow and the signal activates the main pump in the boiler room? Obviously there would be some calculations involved for sufficient flow to trigger the flow switch/meter etc.
