Discuss T4 5w fluorescent tubes in the Lighting Forum area at ElectriciansForums.net
Those type of fluorescent lamps are a pain. The number of different lengths is unbelievable, and some are only slightly longer than others.
A lot of places seem to out of stock, they're probably no longer produced,
As DPG tho' check length before buying and whether you've got white as below or warm white or other colour,
Different length and wattage,, if it is 5w the length will be between theses 2,
Note the ones below are T5, slightly larger diameter
6w 210mm
6w 210mm
Thanks snowhead - the Knightsbridge 6W T4 is the right length. I think you've solved my problem.
or rip out and replace with LED. long term benefit.
Reply to T4 5w fluorescent tubes in the Lighting Forum area at ElectriciansForums.net
One of the fluorescent tubes in my undermount lighting system burnt out. There are 3 independent tubes/ballasts under the length of the kitchen...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hello! Hope you’re all keeping well! I’m replacing a fluorescent tube light which had an electronic ballast fitting - I’ve ripped this out and...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Hi. As per subject heading. We have a lot of these florrie fittings at our unit that we'd like to change to LED. The manufacturer - DEXTRA -...
